فهد مراد
2021-09-10 12:20
The reverse camera display is glitching. Has anyone experienced this and knows how to fix it? It's been checked and seems like it's not an issue with the camera itself. Urgent!
سلمان بلال
سلمان بلال2021-09-12 19:51
Is the connector loosely connected?
Have you encountered a situation where the reverse camera image is missing the borders and only the image is displayed? How can it be restored to normal?
If you want to add a reversing camera to your 207, you can follow these general steps: 1. **Choose a Compatible Camera**: Make sure the reversing camera is compatible with your Peugeot 207 model. 2. **Purchase Necessary Equipment**: You'll need the camera itself, a compatible monitor, and any necessary wiring or connection kits. 3. **Installation**: - **Mount the Camera**: Usually on the rear license plate area or bumper. - **Run the Wiring**: Connect the camera to the monitor and power source. This often involves routing the wires through the car's interior. - **Connect to Power**: Typically, the camera is powered by the reverse light circuit, so it activates when you shift into reverse. 4. **Testing**: Once installed, test to ensure the camera activates correctly and the image displays on the monitor. If you're not comfortable doing this yourself, it's a good idea to have a professional handle the installation to ensure everything works correctly.
The 360-degree panoramic reverse view is not displaying, and sometimes there's a snowy screen. Has anyone else experienced this?
Today when I was reversing, the reverse camera suddenly showed nothing, and the screen started flickering. What's the problem here? Can anyone help me fix this?
The reverse camera frequently goes black, and sometimes it works. How can I fix this? Looking for advice from the experts. 🙏
I feel like the reversing camera image is not clear. Can I replace the camera individually?
After the vehicle system update, the reversing camera is lagging. Why hasn't this been fixed yet? The updates seem to be getting worse... Haven't other car owners reported this issue?
The 2017 flagship model has a reverse rearview camera that doesn't tilt down, even though the setting is checked in the car's system.
It seems like there is no automatic high beam feature, and when reversing, there is distance display and a warning sound. It doesn't seem to have automatic braking. Is it because the reversing speed isn't fast enough?
Ford Ford F 150
Ford F 150AED 199,395 ~ 300,000Gasoline & Hybrid
