Hi everyone, I need some advice. I bought a second-hand 2017 F150 XLT model, not sure from which country. Here's the issue: No matter what the setting is, when I shift gears, the low beam lights turn on. If I turn off all the lights, the daytime running lights don't come on, but when I shift gears, the low beam lights turn on. When the automatic headlight setting is on, the daytime running lights come on, and in park mode, the low beam lights don't turn on, but after shifting gears, they do. I'm wondering what could be causing this and if there's a solution?
How to turn off the daytime running lights?
The gear shift light for the 150 isn't working. Could it be that a button hasn't been turned on? The P, R, D indicators don't light up at night when the car is running.
4Why do the low beam lights on the Ford F-150 Raptor turn on in all gears except for park?
5How do I turn on the daytime running lights for a 2021 T99?
6The dashboard is indicating a daytime running light malfunction, but I haven't noticed anything wrong. The daytime running lights are functioning properly.
7How do you turn on the Elite 517's daytime running lights? It seems like they don't exist.
8Can daytime running lights be turned off?
9Who knows how to turn off adaptive high beams? I set it up and found that when I manually turn on the low beams, the dashboard indicator light goes off, and I still can't figure it out.
10How do I turn on the daytime running lights?
