Has anyone encountered engine noise in a 2019 F150 with 60,000 km? The mechanic says it's a common issue and suggests dismantling the engine to fix the gears.
Has anyone encountered a situation where the 2017 Smart car doesn't respond when put in reverse gear, and the engine warning light is on?
Is there a good way to fix the plastic noise in the gear shift of the 2019 Classic Sylphy? I've been to the dealership four times, but they haven't fixed it!
When driving a manual 1.5L Mazda in fifth gear at 80 km/h, what is your engine's RPM?
4Should I change the transmission oil for a 2019 GAC GS5 270 Premium Edition with 60,000 km?
5Is it necessary to fix the issue if the oil level drops to the lower limit on the dipstick after 5,000 kilometers? Why is there oil leaking from the pipe and turbo area at the back? Has anyone else experienced this problem? The mechanic suggests replacing the oil separator. The car has 60,000 kilometers.
6Does the 2019 model with 1.4T engine need a transmission oil change at 60,000 kilometers? Some say it's maintenance-free, while others say it needs to be changed. I'm not sure what to do. Have any of you changed it?
7Today, my car suddenly won't start and won't shift gears. The screen displays a message saying "Please shift to P or N." Have any of you encountered this situation before? What's the solution? 🤦♂️🤦♂️🤦♂️
8What should I do if the touchscreen stops working? The dealership said it's a common issue, and since it's out of warranty, they suggested I replace it myself (which is quite honest of them). Has anyone else encountered this problem? Which type of screen is suitable to replace it with? 😊
9Why has there been frequent gear lag recently? It's a 2019 model with a 1.4T dry dual-clutch. After picking up speed and then braking, the gear doesn't match the speed. For instance, it's in 6th gear at 45 km/h and 5th gear at 35 km/h, but it doesn't downshift further. It upshifts quite eagerly. Went to the 4S shop, and they said the engine isn't strong enough, and the gearbox can't be adjusted?
10Has anyone encountered an issue with a 2017 Skoda Octavia where the gear doesn't shift up when accelerating, or it drops from D3 to D but doesn't move when accelerating? Any advice on how to fix this?
