حسن سهيل
2022-02-24 00:31
Does your car's transmission have significant jerking? When I shift into reverse, I can hear a noticeable clunk inside the car. Is this a serious issue?
عبدالرحمن جابر
عبدالرحمن جابر2022-05-14 19:33
Check the transmission and differential.
2
محمد أنور
محمد أنور2022-02-28 15:13
Sometimes when I'm going uphill, the transmission shifts very roughly. I'm not sure if that's normal. Now, when I'm on a long uphill, I switch to 'M' for manual shifting.
عبد عزيز عمر
عبد عزيز عمر2022-02-28 02:16
Common issues with the Raptor
نايف شعيب
نايف شعيب2022-02-25 17:03
It is normal for there to be a sound when shifting into reverse gear.
نايف نجيب
نايف نجيب2022-02-25 07:09
Clean the throttle body, then perform a matching process and run the vehicle smoothly through gears one to ten.
I heard that the 4AT transmission has serious jerking issues. Can any car owners share their real experiences?
Foton Tunland E7, a car from September 2020, has been driven for over 10,000 kilometers. The gear grinding issue when shifting into reverse is very serious. Can any expert provide some guidance?
Does the original factory condition of the Navara automatic transmission make a sound when shifting into reverse gear?
I have a new 2022 2.8 diesel GR version. When the car is cold, there's a noticeable jerk when shifting into reverse. After driving for a while, this symptom disappears. Do you know what might be causing this?
What could be the reason for a vehicle with an 8-speed automatic transmission to jerk when shifting from 3rd to 2nd gear?
I have a question. Today while driving, I noticed that the gear shift lever on my automatic transmission can be shifted without pressing the button on the handle. Is this a problem?
Do you also hear noise from the engine while inside the car?
Does your Jetta automatic also have a noticeable jerk when shifting gears?
Ford Ford F 150
Ford F 150AED 199,395 ~ 300,000Gasoline & Hybrid
