Do you have any issues with the rear wheel bearing noise on the F150? It's not very noticeable when driving, but when I shake it hard, there's a slight noise. Is it a big concern? Do I need to replace it? 🙏
2015 Subaru Outback with 50,000 km, the brake feels very hard when starting the car, but it's normal after starting. What could be the reason?
Do cars make noise when they're running?
4There's a rattling noise like a loose plastic shell when accelerating while driving, but it's not there when revving in neutral. The noise also disappears when you press the accelerator pedal down hard after accelerating.
5Friends, when driving at 120 km/h on the highway, there's a humming noise coming from the chassis. What could be the reason? Bearings have been ruled out first.
61. Is it normal for the acceleration of the HiPhi Z model to be very slow, taking about 10 seconds to reach 100, when the battery is around 15%? 2. Is it normal for there to be noticeable wind noise inside the car when driving at speed? Asking fellow car enthusiasts for some answers. 🙏
7Why does the newly purchased car make a slight noise when moving forward with the left rear wheel, but not when reversing?
8The 2023 model 3.0 is shaking a lot at idle, and there's a buzzing noise when starting. Does anyone know what might be causing this?
92018 Peugeot 308 1.6L has a clunking noise when turning the steering wheel. Replaced two shock absorbers and the left strut mount bearing, the noise reduced but it's still there.
10My car is a 2.0 naturally aspirated engine. When I gradually accelerate past 80 km/h, the car shakes a few times, and then it stops shaking. However, if I press the accelerator hard, this doesn't happen. I wonder what's causing this.
