عبدالله فاتح
2024-10-06 20:47
It seems like there is no automatic high beam feature, and when reversing, there is distance display and a warning sound. It doesn't seem to have automatic braking. Is it because the reversing speed isn't fast enough?
أحمد عائشة
أحمد عائشة2024-10-12 23:33
My car was stopped several times while reversing.
عبدالله شهيد
عبدالله شهيد2024-10-08 12:20
Once you press the headlight switch down, if the screen displays a white light symbol, it means the automatic headlights are on.
محمد عَبْدُ الْعَزِيز
محمد عَبْدُ الْعَزِيز2024-10-07 00:29
It has automatic high beam and emergency automatic reverse braking.
Has anyone modified the LED headlights on a Kia Pegas? I'm thinking of replacing them because the halogen lights don't seem bright enough.
The reverse camera display is glitching. Has anyone experienced this and knows how to fix it? It's been checked and seems like it's not an issue with the camera itself. Urgent!
Hey folks, are your car lights bright enough? I'm thinking about changing mine because they don't seem bright, but it looks like I have to remove the entire headlight to do it. Has anyone done this before? Any advice?
Hey guys, my automatic Kia Sportage isn't moving when I shift into reverse. It only starts backing up when I give it some gas. Any ideas?
Can the daytime running lights be replaced separately? I modified the headlights, and it seems like the daytime running lights got damaged; their brightness isn't enough. It's a 2009 model.
Hey folks, the left turn signal on my 2020 180V Automatic UP isn't working, and the dashboard blinks really fast. What should I do?
Hi everyone, I'm looking for advice from fellow Grand Cherokee owners. A braking distance of 43 meters seems pretty bad. Has anyone done any modifications? What brands did you use? Is it enough to just replace the brake discs, calipers, and pads? What's the braking distance after modification? Also, has anyone switched to LED headlights? How's the performance? Which brand did you go with?
Does the 2017 base model 4WD have an automatic locking feature when leaving the car? Mine doesn't seem to lock.
When I suddenly shift to reverse gear, the 360 camera doesn't display. The screen isn't even black; it shows nothing at all. Do you have any idea what could be happening?
