محمد هارون
2024-10-19 21:28
It seems like the car batteries are not from high-end manufacturers.
From the picture, it seems like a convertible sports car, but since the video didn't provide an introduction, it's uncertain whether it is or not.
Apart from McLaren, which other sports car manufacturers use Le Mans engines?
I've heard from my friend that HiPhi is really popular lately and is considered the most luxurious among Chinese-made cars. Is it really that good? It seems to be for high-end consumers. Can you still test drive during the pandemic? Are there any discounts? Can someone who bought it share their experience?
The Jetta car manufactured in September 2018 is likely the 2018 model year.
It seems like the car key is out of battery, and the car won't start.
What do you think about this car with the low-end model at 219,800 RMB, the mid-range model at 239,900 RMB, and the high-end model at 269,900 RMB?
Why is it that the high-end X and S are about the same, but the low-end X is much more expensive than the S? I really like the X. [crying]
The car doors won't open, and there's no response inside. What's going on? The battery seems to be charged.
Should I choose the 2024 Zeekr 009 with a 400V long-range 140kWh battery or the 800V high-voltage 108kWh battery? Any advice from fellow enthusiasts?
