How do you upgrade your car's infotainment system? And why do the wipers make so much noise and vibrate a lot? They're even worse than those on a van!
The taillights of the GTR are truly impressive and exude a powerful presence. I fell in love at first sight. They seem even more imposing than those of a Ferrari.
When driving a 206 with a 1.6 automatic transmission, whether on the highway or at low speeds, the engine noise becomes very loud once the RPM exceeds 2800. There's a buzzing sound inside the cabin that is even louder than the wind noise—it's really loud! When the car is idling after warming up, there's a noticeable vibration if you hold the steering wheel or sit in the seat. What could be causing this? Looking for guidance from experts!
How do I upgrade the infotainment system on a 2020 Jetour X90?
4Hey buddies, does anyone have a rattling noise from the passenger side dashboard? My car is from 2021 and has less than 60,000 km. It happens when I turn on the power, while driving, and sometimes even when it's off. The noise also appears when I turn on the AC and occasionally when using the wipers.
5I tried upgrading my Nissan Sunny's low-spec dashboard to a high-spec one, but it failed due to a loose connector. Now, I can't even reinstall the original low-spec dashboard because the wiring is all messed up. Can anyone provide the dashboard wiring information? What should I do? Help needed 😭😭😭
6Hey guys, quick question. Has anyone with the 2021 Diamond Edition upgraded to LED lights? Did you change the lenses too? Also, for those who do maintenance outside the dealership, what brand of engine oil are you using?
7Once the speed reaches 80, there's a lot of wind noise, and the doors feel like they're leaking air, but I can't find the exact spot. Is this a common issue or do the doors have a problem?
8I got my Defender 110 less than 4 months ago, and the wipers are already leaving a lot of water streaks. Has anyone else experienced this? What brand of wipers did you switch to?
9Do fellow car enthusiasts usually apply the film provided by BYD, or not? I've heard a lot about salespeople promoting upgrades.
10How do you upgrade your car's infotainment system? And why do the wipers make so much noise and vibrate a lot? They're even worse than those on a van!
