Does the EX3 Kungfu Bull support remote air conditioning control via a mobile app? Is there an option to modify it for external power discharge, and is it effective?
The Viano has a power leakage issue. In less than a week, the battery is completely drained, even the remote control for the doors doesn't work. Still can't figure out the cause.
Does the electric Lavida support external power output, or are there any accessories that allow it to output power?
Does the HiPhi X have an external discharge function, and what is the power output in kilowatts?
4Can the central control screen of the 2019 Hongqi H7 1.8T be modified to support wireless CarPlay?
5Dear car enthusiasts, can the 2020 1.5T model be controlled remotely via a smartphone?
6Why is there no sound when I connect Bluetooth after modifying the Patrol's central control, even though the music app built into the central control has sound and shows that it's playing? 😢
7Does the BYD E2, 24 Glory Edition have remote charging management and scheduling services via the mobile app? I checked the spec sheet, and it doesn't mention these features. How come it's the same BYD app but with fewer functions? Could any fellow car owners who have bought it help answer this? 😂😂
8Does the EX3 Kungfu Bull support remote air conditioning control via a mobile app? Is there an option to modify it for external power discharge, and is it effective?
9Does this car have remote start via mobile phone?
10There could be several reasons why the music USB drive isn't responding when plugged into the USB port of your car or other device: 1. **Compatibility Issues**: Some car USB ports or devices may have compatibility issues with certain USB drives or file formats. Ensure the music files are in a supported format like MP3. 2. **File System Format**: Check if the USB drive is formatted in a compatible file system, such as FAT32 or exFAT, which are commonly supported by car audio systems. 3. **USB Port Problem**: The USB port itself might be faulty. Try plugging the USB drive into a different port if available. 4. **USB Drive Issue**: Although it works on your computer, there might be an issue with the USB drive that affects its performance in other devices. Consider testing with another USB drive. 5. **Device Settings**: Check the settings of the device you're plugging the USB into. Some settings might need to be adjusted to read external USB storage. 6. **Power Supply**: Ensure that the device has enough power supply to read the USB drive, especially if it's an older model or if there are multiple devices connected. Try troubleshooting with these suggestions to identify the cause of the problem.
