Does anyone know why the same system has been upgraded to wireless CarPlay abroad, but not in China? It seems similar to the EM90 system, but the EM90 can read USB drives directly. Why can't this smaller car do that? 🤔
Does the 2018 Macan have CarPlay? How can I enable wireless navigation on the car system?
The claim is that the Vito is essentially a cargo van abroad, similar to a minivan in China, and was later introduced and gradually transformed into a business vehicle domestically. Meanwhile, the V260 series is said to be the true business vehicle. Is this claim accurate?
Does anyone know why the surround view camera won't turn on? Also, how do you upgrade the system when you're abroad?
4There could be several reasons why the music USB drive isn't responding when plugged into the USB port of your car or other device: 1. **Compatibility Issues**: Some car USB ports or devices may have compatibility issues with certain USB drives or file formats. Ensure the music files are in a supported format like MP3. 2. **File System Format**: Check if the USB drive is formatted in a compatible file system, such as FAT32 or exFAT, which are commonly supported by car audio systems. 3. **USB Port Problem**: The USB port itself might be faulty. Try plugging the USB drive into a different port if available. 4. **USB Drive Issue**: Although it works on your computer, there might be an issue with the USB drive that affects its performance in other devices. Consider testing with another USB drive. 5. **Device Settings**: Check the settings of the device you're plugging the USB into. Some settings might need to be adjusted to read external USB storage. 6. **Power Supply**: Ensure that the device has enough power supply to read the USB drive, especially if it's an older model or if there are multiple devices connected. Try troubleshooting with these suggestions to identify the cause of the problem.
5Can the USB port in the car be used just for charging? Why can't it connect to the car's infotainment system?
6Why doesn't the Zebra system support CarPlay?
7Why can't the car's system connect to CarPlay?
8Are there any cases of EHS9 owners upgrading their car systems to CarPlay? It feels so inconvenient without CarPlay. 🤔🤔
9Why can't my newly purchased USB drive be read and why does it show as not connected?
10Does anyone know why the same system has been upgraded to wireless CarPlay abroad, but not in China? It seems similar to the EM90 system, but the EM90 can read USB drives directly. Why can't this smaller car do that? 🤔
