طب حسن
طب حسن
Jan 23
Is it difficult to shift gears right after starting the car?
نايف رائد
نايف رائد2021-02-09 21:04
I can't say if shifting gears is good, but once you buy it, you'll definitely get a workout!
أحمد انهايان
أحمد انهايان2021-01-23 10:38
After starting the vehicle, it's indeed a bit difficult to shift gears because the engine and transmission aren't fully lubricated yet. It's okay to wait a little.
I have a manual 1.3 model from 2011. It's difficult to shift from first to second gear, and there's a loud gear noise. What could be the issue?
It's probably difficult to buy a new Changan Yuexiang now, right?
The car is difficult to start two hours after turning off the engine.
Why can't I shift gears often after starting my new Defender 130?
Why is it difficult to engage reverse gear in a 2021 manual transmission?
What could cause a loud banging sound when I shift gears after the car has been parked overnight?
[Shocked] What's up with this car? Starting in S mode, I floored the pedal, the RPM hit 4000 and it was still in 2nd gear without shifting up automatically. It only shifted to 3rd gear after releasing the throttle for 3 seconds.
Guys, I have a 2017 1.6 Zhixing. Last month, while driving, it showed a message to shift to P gear for repair, but it disappeared after a while. This morning, it reported a transmission fault, but after starting the car, it was gone again. What's going on?
Skywell ET5
Skywell ET5BHD 18,468Electric
