The fuel gauge of the Yingku 1.5.por starts to alert when the range is down to 130 kilometers. Also, there's an alert when the rear seatbelts are not fastened. Any solutions, folks?
Hey everyone, I recently noticed a rustling noise near the B-pillar on the passenger side when driving over bumpy roads. I've had the car for a year, but this just started happening. It doesn't make noise on regular bumpy roads, only when the car sways side to side. I've tried fastening the seatbelt and applying grease to the buckle, but the noise persists. Has anyone else experienced this? Any suggestions on how to fix it?
I also like the idea of getting an Iveco for traveling. However, I feel a bit concerned about safety since there's no airbag or side curtain in the back when taking kids along. Is there any solution for this?
There's a rattling noise like a loose plastic shell when accelerating while driving, but it's not there when revving in neutral. The noise also disappears when you press the accelerator pedal down hard after accelerating.
4Hey folks, I have a 2012 Grand Cherokee 5.7. Recently, the sound for the steering alert, seatbelt alert, and radar alert has disappeared. I guess it's probably an issue with the buzzer. But where is this buzzer located?
5Hey folks, when you switch to LED bulbs, do you also change the lens?
6Hey folks, does your 95 feel jerky when slowing down? I feel the jerkiness is quite noticeable, but I see comments saying there's no jerkiness. 🤔
7Hey folks, quick question. Is it normal for a 2019 Toyota Fortuner to make a loud noise when starting, but then it quiets down once the speed hits around 30?
8When driving the Kamiq, if a red "P" appears on the dashboard and there's a beeping sound similar to the seatbelt alert, what could be the issue? Can anyone advise? Thanks!!
9Hey folks, when starting the car cold and switching from P to D, the transmission makes a clunking sound. Also, when parking and switching from D to P, the car lurches forward a bit. Any idea what's causing this?
10I recently bought the 2024 Tiida Intelligent Edition and it's my third time driving on the highway. When I reached 130 km/h, I noticed that after exiting the highway, the steering wheel needs to be slightly turned to the right to go straight. If I keep it centered, the car veers to the left. Is this normal? Also, is getting a wheel alignment expensive?
