خالد طارق
2024-11-07 08:44
Does anyone else experience a squeaking noise from the AC in their car? Especially when you first start the car, it gets less noticeable after a while, but if you turn up the AC fan, it comes back. It seems to be coming from the right side of the car's front.
مسعود عبدالرحمن
مسعود عبدالرحمن2024-11-07 10:39
Check if the noise from components is caused by the temperature difference when the air conditioning is turned on. In summer, there's a sound when cooling, and in winter, there's a sound when heating, but it disappears after about a minute.
عبدالله شجاع
عبدالله شجاع2024-11-07 10:25
There is a slight noise when it's not turned on.
عبدالرحمن طاهر
عبدالرحمن طاهر2024-11-07 09:07
There might not be any major issues, but there could still be some minor ones. If you want to resolve them, it's best to visit a repair shop.
خالد طارق
خالد طارق2024-11-07 08:49
There was already some wind noise from the left A-pillar, and now there's noise from the right side as well. [I need some peace]
It is said that Acura is exiting the Chinese market. Will there be imported cars coming back later?
When you press and hold the AC button on the Arrizo 3, the compressor works and cool air comes out. However, once you release the button, it automatically springs back and the button light doesn't turn on. What could be the issue?
Is it normal for the fan of a 2015 Sharan with 150,000 km to keep running at high speed after turning off the engine and removing the key, especially after driving 30 km with the AC on? The current outside temperature is 39 degrees. Looking for advice from fellow car enthusiasts.
When you start your 2019 model car and turn on the AC for the first time, you hear a noise like the fan suddenly stopping. What's causing this? It only happens once and then works normally afterwards.
Hey car enthusiasts, does anyone else notice a squeaking noise with the ID.3 brakes? Especially a "squeak" sound.
Hey folks, how long did you wait before hitting the highway? I've actually been driving for less than two months, or maybe two years. The car's been sitting back home and I'm worried it'll just go bad. Any advice from those with experience? Much appreciated 🙏🙏🙏
Does anyone else experience wind coming through the headliner when the AC is on (especially when the fan speed increases)? I can feel a noticeable draft when I touch the driver's side seal. There's also a whistling sound when the windows are closed. Is there a car owners' group? I'd like to join.
Do you guys experience a squeaking sound when the front wheels go over a speed bump or curb?
Does anyone with a 2022 Forester experience a rubbing sound from underneath the car when driving at low speeds with the AC on?
To turn on the heater without the AC light coming on, you usually need to adjust the settings on your car's climate control system. Make sure that the AC button is turned off. If your car has an automatic climate control system, try switching to manual mode and adjusting the temperature and fan settings manually. If the AC light still comes on when you activate the heater, it might be due to the car's design to dehumidify the air, in which case you may need to consult your vehicle's manual or contact a service center for further assistance.
