Can the seats of the Supernova Pro be retrofitted with ventilation and an independent blower added for the rear air conditioning at the 4S dealership? It's too hot, and the air conditioning is really poor.
How to adjust the rear overhead air conditioning to hot air in the 2018 Previa? Looking for expert advice.
Hey everyone, just wanted to ask: Why does the JETOUR X95 blow hot air when I turn on the seat ventilation? Thanks!
For the 2017 GWM Haval model with 110,000 km, if the air conditioning isn't blowing air until the fan speed is set to maximum, or the AC needs to be turned off for a few seconds before air comes out, there might be an issue with the blower motor or the air vents. It's best to have a professional check the blower motor and the vent system for any blockages or mechanical issues.
4When the air conditioning blows cold air for a while and then switches to hot air, and after being turned off for a bit, it works again before reverting to hot air, it's puzzling. Interestingly, this issue doesn't occur on rainy days or when the weather isn't too hot. What could be the cause of this situation?
5Is there water in the front passenger seat area? Could it be that the air conditioning drain is clogged?
6Is there anyone who has added rear air vents for a small car? It's really hot in the back seat.
7Could anyone recommend a good seat ventilation cushion? It's so hot driving in the summer. How do you all deal with it?
8The seat ventilation makes noise but doesn't blow air. The dealership said it might be the sponge slipping, and repairing it would require removing the seat and replacing the sponge, costing over 1000. Has anyone experienced a similar issue? How did you handle it?
9Can the seats of the Supernova Pro be retrofitted with ventilation and an independent blower added for the rear air conditioning at the 4S dealership? It's too hot, and the air conditioning is really poor.
10The official film from the Skoda 4S dealership that came with the Mingrui Pro has been used for two years. When would be a good time to replace it?
