صعدة سلمان
2024-08-24 10:38
Can the Chao Xing Ran 1.5t Pro use 95 octane gasoline?
Comments( 9 )
أحمد بندك
أحمد بندك2024-09-04 10:42
[Smile] Adding 98 is also fine!
يحيى عبدالله
يحيى عبدالله2024-08-28 13:56
I don't recommend it. There's an issue with the ignition timing design. Try to use regular fuel more often.
عبد العزيز إدريسي
عبد العزيز إدريسي2024-08-25 06:30
92 is the minimum standard. What else can't be added [I want to be alone]?
عبدالرحمن طاهر
عبدالرحمن طاهر2024-08-24 23:01
You can use RON 98.
محمد فهد
محمد فهد2024-08-24 21:35
The car manual standard is to use 92, but if you want to use 95, that's fine too. Even if you use 98, no one will stop you.
علي كاظم
علي كاظم2024-08-24 20:55
Eating whole grains every day and occasionally having refined grains is okay.
سعود وي
سعود وي2024-08-24 20:02
Of course, it depends on your wallet.
محمد نظيف
محمد نظيف2024-08-24 15:21
Just use 92. Go to a better gas station.
محمد فهد
محمد فهد2024-08-24 11:20
Adding 98 is fine.
