حسين معاوية
حسين معاوية
Nov 25
Is it convenient to drive this car into an underground garage? Would it be uncomfortable on steep slopes? Does it have adjustable suspension?
سلمان كلثوم
سلمان كلثوم2023-11-29 10:12
This car is also short, but its chassis isn't low. My 86 is 3 cm lower than the Emira and it doesn't scrape. Of course, that's assuming the parking garage isn't too old. Most mall parking garages are fine.
سلمان كلثوم
سلمان كلثوم2023-11-29 09:44
If you use the original shock absorbers, you won't scrape in normal parking garages. Only in very old parking garages might you scrape.
عبدالله مأمون
عبدالله مأمون2023-11-25 21:09
I saw a blogger on Bilibili who modified an air suspension [grin][grin][grin]
علي مصطفى
علي مصطفى2023-11-25 14:19
It's okay, the chassis height isn't that low, and this one doesn't have chassis lifting.
Will the carbon fiber at the front of the 600LT affect its clearance significantly? I usually drive into underground garages and over speed bumps. I've driven my friend's 488 and didn't have any issues. Can the 600LT handle the same places that the 488 can?
Why does my car's suspension feel like I'm driving a three-wheeler?
How is the McLaren 720s for daily use? Test drives don't really give the full picture. I've seen on TikTok that McLarens often have minor issues. Can any owners share specific problems? Is the suspension safe for speed bumps and underground garages? I'm planning to get one soon. Does the mileage make a big difference? Currently looking at one with 6,000 km and another with 30,000 km.
Does the new Jimny come with a differential lock? What type of suspension does it have?
Does the Accent have electrically adjustable side mirrors?
Does the standard wheelbase have air suspension?
When driving, if the car suddenly doesn't respond when you press the accelerator, and even flooring it doesn't increase the RPM, but releasing and pressing it again solves the issue, this could be a problem. When starting on a steep slope, if the car feels powerless and sometimes can't climb, requiring several attempts to increase RPM, there might be an issue to address.
Does the 2024 BYD e2 Automatic Glory Edition have an S gear for descending long slopes?
Lotus Emira
Lotus EmiraTBDPetrol
