عبدالله هاماوي
Mar 19
Is it true that the air grille of Lotus electric cars is prone to damage?
Comments( 8 )
The tire loses air slowly, needing to refill every three to four days, but the tire isn't damaged. What could be the reason?
Is this car prone to breaking down? Is it better to buy this one or the TT convertible?
Hey folks, I've heard they say it's prone to engine seizure. Is that true?
4How to repair a damaged chrome strip on the front grille, or should I replace the entire assembly?
5Is it true that the air grille of Lotus electric cars is prone to damage?
6Do you think the grille of this car looks uglier the more you look at it?
7For the Prado 120, when choosing a rear lock, should you go for an electric lock or an air lock? If you choose an air lock, you will also need to buy an air pump, right?
8Will running the air conditioner on a Kia Seltos for 2 hours while stationary damage the car? I've heard that the manual says idling is bad for the car?
9Does starting in second gear damage the car?
10Will a damaged air resonance box affect the performance of a 2013 Mazda 6?
