حسين فاطمة
Can I plug a home charger into the fast-charging port on the left side, considering that my parking space has more room on the left and the right side is against the wall?
Can a home charger for the 2017 X90D charge the 2023 X Long Range?
My 2019 Model 95, the USB port next to the cigarette lighter on the center console isn't working. It doesn't charge my phone, and when I plug in a USB drive, there's no response. What's going on?
In six months, I've driven 7,000 kilometers and have been using fast charging outside all the time. The mileage and display match up normally. Recently, I noticed the power drop is significant—three times the usual rate. The 4S shop checked and found no issues, suggesting that it might be due to fast charging causing a false charge. They recommended using the original slow charger. Initially, using the original slow charger seemed fine, but recently, the power drop is double what the display indicates. After charging, sometimes it's good, sometimes it's not. What could be the problem?
4Does no one really care about the car's width? Including the side mirrors, it's 2.4 meters, and when folded, it's still 2.2 meters. This width feels more intimidating than the 5.68-meter length to me. When parking outside, with a length of 5.68 meters, at worst, you can let it stick out by 30 or 40 centimeters, and passing drivers can just steer a bit to avoid it. But a width of 2.4 meters really makes parking a big issue. Perpendicular parking spaces are the most common, and a standard parking space, including the boundary lines, is 2.4 meters, which basically means it takes up the entire space. If there's a car on the right side, parking this car to the left of it makes it almost impossible for the other person to get in. If you park on the right side of another car, it might be slightly better; at most, the other person might have to move the car out a bit to let passengers get in from the passenger side. Of course, if you fold the mirrors before parking, you can give the neighboring car an extra 20 centimeters of space, but most people probably find that hard to manage.
5Can I plug a home charger into the fast-charging port on the left side, considering that my parking space has more room on the left and the right side is against the wall?
6Does the gullwing door of this car really get easily scratched in tight spaces? I've watched many videos where it often gets scratched in underground parking lots or places with cars on both sides.
7I'm new to cars. Last night, I didn't see clearly while turning and scraped against a pile of sand and stones. Three-quarters of the left side skirt is scratched, and there are one or two scratches on the front and rear doors [facepalm]. Any advice from the experts on how to handle this?
8Is it normal for the left side of the hood on the 2019 HS 2.0 Super Edition to be hot after parking? After about half an hour, it cools down and the whole hood is warm, but the temperature is acceptable.
9Has anyone experienced the fast charging port opening by itself after parking and locking the car? I've noticed it happening three times already.
10I can't charge my electric Lavida, thought it was a grounding issue (there's a grounding wire left by the developer in the electrical box), so I connected it to the ground as well, using two 60cm grounding rods and a 50cm grounding angle iron, but it still sometimes charges and sometimes doesn't. Even the portable charger doesn't work. It's driving me crazy. When I took it to the 4S dealership, it charged fine. They updated the car's system, but it still won't charge at home. I tried two neighbors' charging stations, but it still won't charge. What's going on? Has anyone experienced something similar? It's been over 3 years and 50,000 km.
