عبدالرحمن خلدون
عبدالرحمن خلدون
Dec 13
When the car is parked without turning off the engine, in P gear, and the handbrake is engaged, I notice a clicking sound from the gear lever area every time I press the brake. I didn't notice this issue before, but it happened today. Has anyone else experienced the same situation? I've had the car for over a year and have driven 4,000 kilometers.
عبدالله سعد
عبدالله سعد2024-11-17 17:17
It won't shift gears unless you step on the clutch.
The gear lever on this company car is problematic. After shifting to reverse, the detent stays in the engaged position even when you return it to neutral. You have to push it down to disengage. I didn't pay attention today, and when coasting downhill while pressing the clutch, I directly shifted to first gear without pushing the detent down. As a result, the car stalled and now it won't start at all.
I have a 2018 2.0 4WD Jeep Renegade. When I start the car, while the gear is in the P position and I press the brake, I hear a clicking sound from the gear area. Has anyone else experienced the same issue?
I have a question. Today while driving, I noticed that the gear shift lever on my automatic transmission can be shifted without pressing the button on the handle. Is this a problem?
I was thinking about getting it back then but didn't make a move. What's the situation now? Is it still a good idea to get it, or is there a risk of it failing?
Before driving, I can only shift gears by pressing the shift lock button, and once I shift back to the P gear, I have to press the lock button again to shift! The brake lights are working fine! I recently replaced the handbrake cable and gear cable. Has anyone else experienced this situation?
Today, my car suddenly won't start and won't shift gears. The screen displays a message saying "Please shift to P or N." Have any of you encountered this situation before? What's the solution? 🤦‍♂️🤦‍♂️🤦‍♂️
I accidentally discovered that when switching gears on the Grand Cherokee, there's a noticeable "click" sound from underneath the chassis. However, the driving is smooth with no abnormalities. Have any fellow car enthusiasts experienced the same situation?
Gear won't engage. Every time this happens, I just turn off the car, wait a bit, then restart, and it goes back to normal. Took it to the repair shop, but they couldn't find any issues.
Is it normal for the Haval Jolion Comfort edition to lurch slightly when you park on a slope, shift to P, engage the electronic handbrake, and then release the foot brake?
Hyundai Elantra
Hyundai ElantraEGP 218,000 ~ 1,670,000Gasoline & Hybrid & Petrol
