My car, the Buick Excelle, consumes about 9-10 liters of fuel per 100 kilometers in the city. It seems like the Hyundai Elantra has lower fuel consumption. Is it necessary to switch? Also, how is the Elantra's air conditioning cooling performance? The Excelle's air conditioning is quite weak, and sometimes when I shift into reverse, it blows hot air.
The rear air conditioning vents are not blowing cold air?
The air conditioning in the 2011 Kia Sportage has cool air but isn't cooling effectively. What could be the reason?
When the air conditioning blows cold air for a while and then switches to hot air, and after being turned off for a bit, it works again before reverting to hot air, it's puzzling. Interestingly, this issue doesn't occur on rainy days or when the weather isn't too hot. What could be the cause of this situation?
4Why isn't the air conditioning in my Alto cooling?
5The temperature settings for both the driver and passenger sides are the same, but the passenger side is blowing hot air while the driver side is blowing cool air. What's going on, experts?
6My 207's automatic air conditioning is having issues. The air only blows towards the windshield and can't be switched to other directions. The display on the panel works, but it doesn't actually change. The AC compressor starts, but it keeps blowing hot air. The temperature adjustment panel shows the settings, but the temperature doesn't change.
7Is there anyone who understands why the air conditioning isn't cooling?
8Why is the rear air conditioning not cooling in the 2020 2.0 model?
9Is the warm air blowing on the windshield of your LC120 also weak?
10Is the warm air blowing on the windshield of your LC120 also feeling weak? Is it the same for you guys?
