علي برهان
2024-11-21 13:20
I've heard that the two A-pillars of the Elantra have different strengths, with the passenger side being half as strong as the driver's side. The bumper beam material is too thin. Does anyone know more about this?
محمد شهيد
محمد شهيد2024-11-24 20:24
A few days ago, CIRI just conducted a crash test and rated it as excellent, better than those domestic and joint venture cars. Don't listen to the online haters. After all, the whole country is boycotting Korea, such as Samsung, celebrities, and cars. That's why there are so many haters.
علي هكيل
علي هكيل2024-11-24 09:26
In theory, no, the car frame isn't spliced together. It's formed by stamping steel of the same quality. If different grades of steel were used, how would the joints be controlled? Plus, the cost would increase, and no manufacturer would do that.
سلمان طارق
سلمان طارق2024-11-24 09:17
It's said that the 2023 model has been updated, and compared to the 2021 model, this mid-cycle refresh has made significant changes. The front subframe and A-pillar strength have both improved. 😄
خالد حافظ
خالد حافظ2024-11-21 15:58
People who buy this car don't care about the points you're mentioning, and those who care about these points won't buy this car. 😁
Hello everyone, I have a 2011 Comfort M5, and I've had it for a year and a half without any issues. Recently, there's been a rattling noise on the front passenger side when driving on regular concrete roads, like the sound of knocking on wood, which is quite annoying. There's no noise on highways or asphalt roads. What could be the reason for this?
Hey everyone, I recently noticed a rustling noise near the B-pillar on the passenger side when driving over bumpy roads. I've had the car for a year, but this just started happening. It doesn't make noise on regular bumpy roads, only when the car sways side to side. I've tried fastening the seatbelt and applying grease to the buckle, but the noise persists. Has anyone else experienced this? Any suggestions on how to fix it?
I feel like the brakes on the McLaren GT are really stiff. Is it possible to modify them later to make them softer? [Facepalm] After being stuck in traffic for half an hour, my right leg is sore. Also, how do you judge the distance on both sides of such a wide car? Every time I drive on narrow roads, I'm terrified of scratching it...
There have been heavy rains these past few days, and the driver's side is leaking, with the A-pillar being wet. Could it be that the sunroof is blocked? Or is there another reason?
When driving above 80 km/h, there's a noticeable noise near the passenger side A-pillar. At higher speeds, like 120 km/h, the noise becomes even louder.
Does anyone know the strength in megapascals of the steel used for the front and rear bumpers of the Xpeng, and the strength of the steel for the A, B, and C pillars? Thanks a lot.
Chery Arrizo 3, sometimes there's a noise above the glove box. When driving, it usually stops, but after turning off the engine, closing the car door might cause the noise again. There's also a similar sound inside the passenger side B-pillar seatbelt. I want to take apart the dashboard to see if something is loose inside, but I'm not sure where to start. I've previously removed the bumper to install a loudspeaker and added a central control screen with a rearview camera. But I'm not sure how to start with the area above the glove box.
Hyundai Hyundai Elantra
Hyundai ElantraAED 76,250 ~ 237,000Gasoline & Hybrid
