Where are his low beam lights?🧐
Hi guys, does the 2017 GS7 1.8T have halogen bulbs or xenon bulbs for the low beam headlights?
As long as the Ford F-150 Raptor is not in the "P" (Park) position, the low beam lights turn on. What's going on?
Why do the low beam lights on the Ford F-150 Raptor turn on in all gears except for park?
4The low beam is as good as nonexistent.
5Suzuki Liana 2013 model! Why do all the lights work except the low beam? Where is the low beam fuse located...
6Hi everyone! Could anyone tell me where the low beam fuse is for a 2013 Liana? All the lights work fine except for the low beam. Does anyone know what the issue might be...?
7Does anyone know why the high beam and low beam headlights keep breaking?
8Where are his low beam lights?🧐
9The low beam is a bit low. Which setting is appropriate to adjust it to?
10I've checked the high and low beam lights outside the car, and they can be turned on and off normally. However, when I switch to the high beams, the dashboard keeps showing a "high beam fault," whereas there is no fault reported for the low beams. Can any experts advise on what exactly might be the problem?
