عبد العزيز سلطان
2024-06-01 10:29
What should I do if the USB flash drive is not responding when plugged in?
طل عبدالله
طل عبدالله2024-06-02 21:24
Wait a few minutes and it will be ready.
أحمد إدريس
أحمد إدريس2024-06-01 16:03
My USB drive is loading very slowly.
نايف مراد
نايف مراد2024-06-01 11:44
If there's no problem with the USB drive, switching to a Philips monitor should work!
I bought a music USB online, but my car can't read it. What format should I change it to?
If the hazard lights don't flash and the trunk won't open when you press the key, what should you do?
What should I do if I can't use the USB port to play music?
My 2019 Model 95, the USB port next to the cigarette lighter on the center console isn't working. It doesn't charge my phone, and when I plug in a USB drive, there's no response. What's going on?
Where should I insert the USB drive in the Hongqi HS7 to play music? I've tried both the slot under the dashboard and the one at the back, but it shows "USB not mounted". What should I do?
Can the 2019 Changan Yuexiang Manual Comfort model use a USB flash drive?
There could be several reasons why the music USB drive isn't responding when plugged into the USB port of your car or other device: 1. **Compatibility Issues**: Some car USB ports or devices may have compatibility issues with certain USB drives or file formats. Ensure the music files are in a supported format like MP3. 2. **File System Format**: Check if the USB drive is formatted in a compatible file system, such as FAT32 or exFAT, which are commonly supported by car audio systems. 3. **USB Port Problem**: The USB port itself might be faulty. Try plugging the USB drive into a different port if available. 4. **USB Drive Issue**: Although it works on your computer, there might be an issue with the USB drive that affects its performance in other devices. Consider testing with another USB drive. 5. **Device Settings**: Check the settings of the device you're plugging the USB into. Some settings might need to be adjusted to read external USB storage. 6. **Power Supply**: Ensure that the device has enough power supply to read the USB drive, especially if it's an older model or if there are multiple devices connected. Try troubleshooting with these suggestions to identify the cause of the problem.
The 2020 model only has one USB port. If you plug in a USB drive to listen to music, you can't connect the car kit. The USB extension ports you bought aren't working, and the USB in the armrest cigarette lighter also doesn't support USB drive for music or connecting the car kit. Do you have any suggestions for using both the USB drive for music and the car kit simultaneously?
Hey car enthusiasts, does anyone know what’s up with the Jietu 2024 Glory Pro's infotainment system not connecting? I plug in the USB and nothing happens. I'm using the original data cable that works fine when I connect my phone to a computer. But when I plug it into the car's USB port to connect to the infotainment system, there's no response at all. I've downloaded both E-Link Driving Assistant and Driving Companion apps on my phone, but neither works. Any ideas?
Mitsubishi Mitsubishi Eclipse Cross
Mitsubishi Eclipse CrossAED 78,900Gasoline
