Is it normal for the doors of a Mitsubishi Eclipse Cross not to close at -20°C and require extra force to shut properly?
Why won't the electric sliding door close properly? I have to press it with my hand to get it to lock.
Is oil consumption a common issue for the Mitsubishi Eclipse Cross? How should it be repaired?
What kind of 0W-20 engine oil is good for a Mitsubishi Eclipse Cross? Any recommendations from those who've changed it? Thanks!
4Does your Mitsubishi Eclipse Cross consume oil?
5Hey car enthusiasts, has anyone experienced their Eclipse Cross hitting 2-3 RPMs at a speed of 20? What's going on?
6The co-driver's window of the Mitsubishi Eclipse Cross can only go up but not down, and the main driver's switch can control the other three windows except the co-driver's, which can only go up but not down. The co-driver's switch also only allows the window to go up but not down. What could be the reason for this?
7Is it normal for the doors of a Mitsubishi Eclipse Cross not to close at -20°C and require extra force to shut properly?
8Where can I buy the original transmission filter and mesh for the 2019 Mitsubishi Eclipse Cross?
9Why do I feel that the soft-closing mechanism on the rear door is less sensitive than the front door? With the same amount of force, the rear door doesn't close properly. Do you guys experience this too?
10Why does the car beep three times when starting, like the sound when a door isn't closed properly?
