How to solve the issue of rapid engine oil consumption in the Eclipse Cross? It consumes 1 liter every 5000 kilometers.
2011 MDX makes a knocking sound like "da da da" when accelerating, occasionally shakes during acceleration, and consumes 1 liter of oil every 2000 kilometers. Should I consider an overhaul?
How many liters per 100 kilometers does it consume in the city?
Is oil consumption a common issue for the Mitsubishi Eclipse Cross? How should it be repaired?
4Can the Eclipse Cross only add 4 liters of engine oil?
5What kind of 0W-20 engine oil is good for a Mitsubishi Eclipse Cross? Any recommendations from those who've changed it? Thanks!
6Does your Mitsubishi Eclipse Cross consume oil?
7How to solve the issue of rapid engine oil consumption in the Eclipse Cross? It consumes 1 liter every 5000 kilometers.
8Does the Eclipse Cross need a transmission oil change after 20,000 kilometers and four years? Thanks.
9Is the third-generation 888 engine, with 70,000 kilometers on it, now burning one liter of oil every 5,000 kilometers? I've always used Castrol Edge 5W40 oil. Does it need a major overhaul?
10Others are saying that the Tank's fuel consumption is between 6 to 7 liters, but why is my car consuming over 11 liters even though it's just over 5,000 kilometers?
