علي نايف
2024-01-05 15:28
How do you guys change the transmission oil, gravity or circulation?
عبد العزيز ماجد
عبد العزيز ماجد2024-02-19 14:38
It's been four years, and I've only driven 15,000 kilometers. Should I change it? [I need some quiet time]
حسين فرج
حسين فرج2024-02-17 11:34
How much does it cost to change two oil filters, including iron filter, paper filter, and gasket?
عبدالرحمن شادي
عبدالرحمن شادي2024-01-16 09:39
Change after just tens of thousands of kilometers? I'm also planning to change at a bit over 40,000 kilometers. I've looked it up online quite a bit. Some say it's best not to change, while others suggest changing after 60,000 kilometers. I'm not sure now.
علي شادي
علي شادي2024-01-07 20:11
Gravity, replace paper filter, wash iron filter.
How many liters of transmission oil does the GA8 need to change? Should it be by gravity?
How many liters of oil does a Mazda 2 automatic transmission take for a gravity oil change?
How often do you guys change the transmission oil for your Wrangler? Just asking, thanks.
Q: For the Taurus 8AT transmission, is it necessary to use a circulation machine to change the transmission oil? Is it required to remove the oil pan for cleaning?
Has anyone changed their transmission oil? How many liters did you use, and did you do a gravity change or a complete flush?
Has anyone changed their transmission fluid? How many liters did you use? Did you do a gravity change or a full cycle change???
Has anyone in the group changed the transmission oil for the 2021 JMC Ford Territory? This model doesn't have a transmission oil filter. Is it better to do a fluid exchange or a gravity drain by removing the oil pan? 🙏🙏
How do I change the transmission oil for a Mazda 6 AT? Should I use the circulation method or the gravity method? It's currently at 76,000 kilometers.
Mitsubishi Mitsubishi Eclipse Cross
Mitsubishi Eclipse CrossAED 78,900Gasoline
