سعود صعدة
2024-02-21 21:38
Has anyone's particle filter gotten clogged? Mine clogs once a year, it's really troublesome. This car doesn't burn it off even on the highway, rarely goes over 2000 RPM, so it basically can't burn off. How do you guys deal with it? Do you just run it in third gear at 6000 RPM to clear it?
Comments( 16 )
نور علي
نور علي2024-03-13 22:09
The start is always the most eye-catching one 😁
أحمد مجدي
أحمد مجدي2024-03-12 14:35
Take it for a highway run.
عمر نصر
عمر نصر2024-03-01 14:21
When starting first, keep it at least at 2000 RPM, typically around 3000. As for overtaking on national highways, I'm not sure; I just know to floor the accelerator. 😁
حسن عبد الحكيم
حسن عبد الحكيم2024-03-01 13:19
It's okay to frequently use the S mode.
أحمد رائد
أحمد رائد2024-02-29 15:43
[I just want some peace][I just want some peace] In economic mode, the start is always at 2000 RPM, what's going on with this?
نايف سعود
نايف سعود2024-02-29 14:53
Caught a road auntie
قاسم علي
قاسم علي2024-02-29 13:08
Just keep the revs high in manual mode usually.
علي محملة
علي محملة2024-02-28 04:57
You can tell right away that they're usually a slow driver.
عبد العزيز محملة
عبد العزيز محملة2024-02-27 21:02
Once the sport mode is activated, the start is at 2000 RPM, how could it not be 2000?
خالد زايد
خالد زايد2024-02-27 12:27
Driving at high speed in a low gear.
It's normal for your NV200 to have a high idle speed of 2000 RPM when you start it cold, and then drop to 800 RPM after about a minute. This process helps the engine warm up. However, if it feels inconvenient, you might want to consult a mechanic to see if any adjustments can be made.
Will driving 5,000 kilometers without adding a cleaner clog the fuel injectors? Do you need to clean the turbo blades at 20,000 kilometers?
When driving a manual transmission car, if you hear a rubbing noise from the engine slightly above 2000 RPM, but it disappears above 2300 RPM, what could be the reason?
The temperature is around minus three degrees, and suddenly today the gear shifting is very slow. It used to shift at around 2000 RPM, but today it goes up to 3000 RPM. The engine is making a humming noise. 😵‍💫 Do any other T-Cross owners experience this situation?
Hey everyone, do you feel like the accelerator is really close to the floor in this car? With a floor mat, I guess you can't hit 6000 RPM. Are you all experiencing the same thing?
How do you turn the headlights on and off?
How do you turn off the rear seatbelt reminder on this car?
Mitsubishi Mitsubishi Eclipse Cross
Mitsubishi Eclipse CrossAED 78,900Gasoline
