علي طيب
2024-12-05 15:53
Brothers, I have a '22 Changan Eado Premium. I used to hear the turbo sound when I gave it gas, but now I can't hear it anymore. What's going on? All I hear is the engine roar.
My 2017 MG GS automatic luxury version has been driven over 108,000 kilometers in five years. A few days ago, while driving on the highway, [when accelerating uphill and pressing the gas pedal deeply, the power suddenly disappeared. I could only hear the engine revving without moving forward]. I checked and confirmed it was in D gear, tried switching to S gear but it didn't help. After turning on the hazard lights to let the cars behind pass, I pulled over, switched to neutral, and then back to D gear, and it could drive normally again. I don't know what the issue is. Could any knowledgeable teachers or friends advise? Thanks [smile].
Hello fellow car enthusiasts, I own the 2019 Premium model. I'm considering installing all the missing loudspeakers without changing the main unit. How do you think the sound quality would be?
Does your engine also make a loud noise when the RPM reaches 2000? Especially when going uphill, all I can hear is the roar of the engine.
I recently went on a highway long trip, and after just letting the car sit for a day, I'm experiencing delayed acceleration. When I press the gas pedal, I can hear a swooshing sound from the chassis. Is it clogged again? Anyway, the instantaneous fuel consumption has increased, which is really frustrating. Has anyone else experienced this? How did you solve it?
Changan Alsvin, ABS and anti-skid faults, diagnostic shows left front wheel speed sensor fault. I replaced it, but the lights are still on. The diagnostic still shows left front wheel speed sensor fault, but all the data streams are there. The fault can be cleared, but it comes back while driving. What should I do?
Changan Yuexiang, ABS and anti-skid fault, diagnostic shows a left front wheel speed sensor fault. I replaced it, but the lights are still on, and the diagnostic still shows the left front wheel speed sensor fault. However, all the data streams are present. The fault can be cleared, but it comes back while driving. What should I do?
I have a 2017 automatic model with 50,000 kilometers on it. Recently, I've noticed three particularly obvious issues: 1. When starting at traffic lights, even with light acceleration, I can hear the engine howling. The fuel consumption spikes to 19.9, the engine revs up to 2000 RPM, but the acceleration is very slow. 2. When driving home from work and going up the parking ramp, I often find that even with the gas pedal pressed, there's no power. The RPM goes up to 3000, and the fuel consumption also spikes. 3. Occasionally, when starting the car, it will shake and then stall by itself. Overall, driving at speeds between 0-40 is uncomfortable, but things improve above 60, especially on the highway. Acceleration and overtaking are fine at higher speeds. It's quite frustrating. Is anyone else experiencing the same issues?
The car has been driven for 5 and a half years, with 94,000 kilometers on it. I've always wanted to switch to 22-inch wheels. Since I haven't really thought about changing cars anytime soon, I want to hear your opinions. Do you think it's still worth spending the money? There shouldn't be any issues driving with 22-inch wheels, right?
