عبدالرحمن بهاء
2021-09-05 17:36
Does your e2 air conditioning compressor make a strange noise? I feel like the sound is a bit loud, and it comes and goes. The salesperson said it's the sound of the compressor when the air conditioning is turned on. Can anyone help me check this?
Comments( 14 )
عبدالرحمن ميك
عبدالرحمن ميك2024-04-13 22:56
The quality of the E2 compressor isn't good. Mine was making the same noise, and I had it replaced under warranty.
عبدالرحمن بشر
عبدالرحمن بشر2024-04-13 21:24
What's that noise? Is there a pig living in the air conditioner?
علي سعود
علي سعود2022-07-14 06:43
It's really hot in July, and I've noticed the sound of the air conditioner's compressor getting louder these days. It might be due to the motor running and the compressor working harder in the heat. However, when I lower the fan speed or turn it off, the sound disappears. The sound from my unit is quite deep, not as sharp as yours.
ابيض عبدالله
ابيض عبدالله2022-07-13 18:12
It should be about right, but recording with your phone might sound a bit harsh.
عبدالرحمن قادر
عبدالرحمن قادر2022-07-12 00:11
When the temperature is high, the cooling fan automatically kicks into its highest setting and becomes extremely loud. It needs to cool both the battery and the air conditioning system.
حسين ميثا
حسين ميثا2022-07-11 23:12
I just got my car a few days ago and noticed the same loud noise.
فهد عل
فهد عل2021-09-06 22:47
My 5th gear noise is also loud, but not as loud as yours.
زياد حسين
زياد حسين2021-09-06 21:19
Your voice is a bit loud.
سلمان جمال
سلمان جمال2021-09-06 20:02
The sound is there intermittently, but it seems a bit quieter.
محمد خدي
محمد خدي2021-09-06 08:29
The sound is indeed a bit too loud.
Is it normal for a loud humming noise, similar to an air conditioner compressor, to come from the front of the car during charging?
Why does the air conditioning compressor keep making noise for a few minutes after parking and locking the car? What could be the reason?
What could be the issue if the air conditioning compressor keeps running even when the AC switch is properly turned off? Does anyone know?
For the 2017 model, if the central control air conditioning vent is weak and you hear a loud noise from the air conditioning even when it's on maximum, but there's not much airflow, how can this be resolved?
Is the issue with the Levante's air conditioning not cooling occasionally, sometimes not cooling at all, and then starting to cool again after driving at higher speeds, related to a common compressor problem?
Is it normal for the BYD e2 to have a loud electric current sound?
Hey guys, how's the air conditioning in your hybrid Yingku? Mine doesn't seem to cool well, and when I went to the dealership they said that's just how GAC's air conditioning is.
After a highway trip, there's this strange noise whenever I turn on the air conditioning. Does anyone know what might be causing it?
Yesterday, I went to the dealership to check the air conditioning pressure. It was at 16 psi and the temperature was 7.6 degrees, and they said everything was fine. But by noon, it wasn't cooling anymore. 🤦‍♂️
What could be the cause of the Mazda 6 air conditioning compressor frequently cycling on and off and making loud noises?
