محمد عباد
2024-04-25 15:18
Do you guys experience a squeaking sound when the front wheels go over a speed bump or curb?
عمر عبد الحكيم
عمر عبد الحكيم2024-05-16 22:51
The sound from the tire under pressure is fine.
Front right wheel makes a noise at low speed.
When my car goes over a speed bump, there's a "clunk, clunk" sound. What could be the reason?
I've had the top-end version of the Venucia Star for a year, and I've driven 4800 kilometers. Now I've noticed that when going over those really low speed bumps on highways, the rear end sways, with noticeable lateral movement at the back. (Speed is under 60, and ESP is automatically on.) Do you guys have the same issue?
I'm wondering if anyone knows what might be causing a noise from the rear wheels of a 2006 4Runner when going over bumps?
It's uncomfortable going over speed bumps, it's very bumpy. What's up with the suspension?
I bought a second-hand Kia Sportage that's 10 years old. When going over bumps or speed bumps, the front chassis makes a creaking noise. I asked a repair shop, and they said it's likely the stabilizer bar bushings have aged. Replacing the two front stabilizer bar bushings would cost over 200, but they also mentioned that changing them might not necessarily solve the problem. Do you think it's necessary to replace them?
Is there any car owner experiencing a noise from the right rear wheel? When the temperature is low, there's a squeaking sound when going over speed bumps. There's no abnormality during normal driving, and it doesn't make noise on bumpy roads. The shock absorber isn't leaking either. The car is only three years old, so it shouldn't be the stabilizer bar bushing issue, plus the sound doesn't seem like it's from the stabilizer bar bushing.
Taurus chassis noise I have a 2019 Taurus, bought in 2021, and it's now at 57,000 kilometers. Recently, there's been a serious noise coming from the chassis, and it gets worse as the weather gets hotter. When the vehicle goes over speed bumps or when the front wheels hit uneven road surfaces at different times, there's a squeaky sound from underneath, like metal rotating inside a rubber bushing. When entering the garage and turning the steering wheel left, there's a clunk noise from the front when the front wheels hit a speed bump. The same clunk noise happens when parking with the steering wheel fully turned while reversing. The noise is very uncomfortable. Any suggestions from fellow car enthusiasts? Has anyone else experienced this?
