Is the official capacity 37 kWh, but now it's only charging to 30 kWh? Could it be a battery issue?
How many kilowatt-hours can everyone charge at once? It's been two months, and the most I've seen was about ten kilometers remaining, charging 29 kWh. Isn't the battery supposed to be 38 kWh? The maximum is just 29 kWh, and it's around 25 kWh each time.
Why does the official spec say the car has a 65L fuel tank, but I can only fill it up with just over 30 liters?
For a 2018 Model S 100D with 80,000-90,000 kilometers, the remaining battery range can be significantly different compared to a 2022 Model 3 or Model Y with a 78 kWh battery. The older Model S may experience some battery degradation over time, affecting its range. When considering a used car, it's understandable to be concerned about the battery's performance and capacity.
4Why is charging slow in the summer? The charging station is only charging at 30 amps. Does anyone know why?
5My E2, with a 47 kWh battery, charges up to 100%, but why does fast charging only add 35 kWh? I've already replaced the power battery due to the same issue, but the problem persists. Please help, it's urgent.
6I would like to ask if the fast charging for the Taycan can only be used at Porsche's official charging stations? Can outside charging stations provide fast charging? How is the charging speed?
7Is the official capacity 37 kWh, but now it's only charging to 30 kWh? Could it be a battery issue?
8Is there anything other than a battery issue that could cause the auto start-stop to show the battery not fully charged on a three-year-old car?
9I always charge when my battery is between 10-20%. I see many people start charging at 30%. Does charging at 30% really help protect the battery better? And do you guys wait until it’s 100% full before unplugging?
10Hello everyone, my E2 used to charge up to 43 kWh, but now it only goes up to 30 kWh. What's going on? It's a car from October 2019 with 190,000 kilometers.
