بشير سلمان
2021-12-18 10:07
I've driven 80,000 km. Is it time to change the transmission fluid? What type of fluid should I use?
علي لطيف
علي لطيف2024-10-25 20:50
Brake oil and brake fluid, haven't reached the 80,000 km mark for replacement yet.
2
خالد شعبان
خالد شعبان2022-09-04 21:20
Where does an electric motor have transmission oil?
I've driven 80,000 kilometers. Do I need to change the transmission oil? Which brand of oil should I use?
What type of transmission fluid should be used for a Mazda CX-7 2.5?
For the BYD Song PULS fuel version, if you're not going to the 4S shop for maintenance, what type of engine oil and transmission fluid should be used?
What type of transmission oil should I use for my Mazda 5? Planning to change it, thanks.
How often should transmission fluid be changed?
How much and what type of oil should I use for a Cetus oil change?
