سلمان خد
2024-07-01 23:23
I can't charge my electric Lavida, thought it was a grounding issue (there's a grounding wire left by the developer in the electrical box), so I connected it to the ground as well, using two 60cm grounding rods and a 50cm grounding angle iron, but it still sometimes charges and sometimes doesn't. Even the portable charger doesn't work. It's driving me crazy. When I took it to the 4S dealership, it charged fine. They updated the car's system, but it still won't charge at home. I tried two neighbors' charging stations, but it still won't charge. What's going on? Has anyone experienced something similar? It's been over 3 years and 50,000 km.
Master, the right side electric door sometimes responds and sometimes doesn't. After manual operation, it works normally again. I've replaced the lock block, sensor seal strip, and sliding sensor. (290,000 kilometers) Any advice?
Why won't the electric sliding door lock properly? I have to press it with my hand to fully close it.
Why won't the electric sliding door close properly? I have to press it with my hand to get it to lock.
My 2013 Sharan's electric door sometimes won't close by itself, and the button doesn't work either. After disconnecting and reconnecting the power, it works again. Does anyone know the reason?
Does anyone know why the water temperature gauge on the 2020 Jetour X70 with 1.5T engine sometimes shows six bars and sometimes five bars? I've already replaced the thermostat, but it still doesn't work.
Car enthusiasts: Sometimes when driving a small car, the D gear won't shift up. The RPM suddenly goes up, but the gear doesn't match. What could be the reason?
I have a 2015 Honda City. Sometimes it takes two or three attempts to start. What's the issue, experts?
My car's trunk won't open electrically; I have to use force to open it manually.
Is it a problem with the ignition switch if the Volvo S40 key is turned to the second position, but there's no power and it reports an engine anti-theft system fault? I changed the ignition switch, and now it's sometimes good and sometimes bad. Sometimes the dashboard lights up, sometimes it doesn't, and sometimes it even starts automatically.
