Have you encountered a situation where the reverse camera image is missing the borders and only the image is displayed? How can it be restored to normal?
Is anyone else having issues with the 2019 model 95's lane assist controller malfunctioning and the reverse camera not displaying a signal? How did you solve it? Any suggestions? 🙏
The reverse camera display is glitching. Has anyone experienced this and knows how to fix it? It's been checked and seems like it's not an issue with the camera itself. Urgent!
Has anyone encountered a situation where the 2017 Smart car doesn't respond when put in reverse gear, and the engine warning light is on?
4Is there a situation where it shifts to neutral by itself when reversing in reverse gear?
5Why won't the panoramic image open? Clicking it doesn't respond, and it also doesn't switch to the camera when I put it in reverse gear. What's the reason?
6Have you encountered a situation where the reverse camera image is missing the borders and only the image is displayed? How can it be restored to normal?
7If you want to add a reversing camera to your 207, you can follow these general steps: 1. **Choose a Compatible Camera**: Make sure the reversing camera is compatible with your Peugeot 207 model. 2. **Purchase Necessary Equipment**: You'll need the camera itself, a compatible monitor, and any necessary wiring or connection kits. 3. **Installation**: - **Mount the Camera**: Usually on the rear license plate area or bumper. - **Run the Wiring**: Connect the camera to the monitor and power source. This often involves routing the wires through the car's interior. - **Connect to Power**: Typically, the camera is powered by the reverse light circuit, so it activates when you shift into reverse. 4. **Testing**: Once installed, test to ensure the camera activates correctly and the image displays on the monitor. If you're not comfortable doing this yourself, it's a good idea to have a professional handle the installation to ensure everything works correctly.
8Hey car enthusiasts, have you noticed this? When you're reversing into a parking spot, the car looks straight, but on the 360 camera, it appears skewed. Before, when I parked using the 360 camera, the image showed the car was straight, but once I got out, the front was actually tilted to the right. And when it seemed straight from the outside, the image showed it was slanted.
9I feel like the reversing camera image is not clear. Can I replace the camera individually?
10Has anyone with a HS7 encountered a camera malfunction where it shows a "cannot connect to camera" message?
