Front right wheel makes a noise at low speed.
Where can I get a comprehensive inspection for an Acura MDX? I just got a 2010 model, and there's a strange noise coming from the front right when I accelerate at low speeds, but I can't figure out the cause.
34, should I buy a low-power front-wheel drive?
4Does this car come with low-speed four-wheel drive and a differential lock?
5Hasn't anyone mentioned the noise issues with this car? In summer, there's some noise from the right rear door area, and in winter, it's from the right front.
6Does your CX-5 make a cicada-like noise at low speeds, especially noticeable when coasting at 60? Have any of you experienced this?
7Is there any car owner experiencing a noise from the right rear wheel? When the temperature is low, there's a squeaking sound when going over speed bumps. There's no abnormality during normal driving, and it doesn't make noise on bumpy roads. The shock absorber isn't leaking either. The car is only three years old, so it shouldn't be the stabilizer bar bushing issue, plus the sound doesn't seem like it's from the stabilizer bar bushing.
8Hello fellow car enthusiasts, my car makes a thumping noise from the right front wheel when I turn left. Does anyone know the reason for this?
9What causes the steering wheel to make a noise when turning the shaft?
10Has anyone experienced a noise from the front right wheel, like a screeching sound, especially when lightly pressing the brakes or driving at 20-30 km/h after braking? The noise is very sharp.
