نايف فؤاد
2024-09-10 10:53
Sometimes when I wait for the RPM to drop after starting the car, the engine noise is really loud. The sound gets louder or softer depending on how hard I press the accelerator, and the throttle doesn't feel as powerful as it usually does, requiring me to press it deeper. However, most of the time, this doesn't happen. After the RPM drops, the noise is normal.
حسن عبد الغفار
حسن عبد الغفار2024-09-12 09:12
I think it's normal because mine sometimes does the same. It works fine, so I didn't bother with it.
خالد علياء
خالد علياء2024-09-10 12:59
It should be normal.
هارون نايف
هارون نايف2024-09-10 12:01
What are the differences between a cold engine and a warm engine?
Does your engine shake after the first maintenance? Mine is shaking quite a bit after today's first maintenance, and the engine noise is louder than before!
Fault code P0504, currently gears 1, 2, 3 are fine, but when switching to 4th gear, the car loses power when pressing the accelerator and doesn't accelerate. The RPM drops very slowly when pressing the clutch. Has anyone else experienced this?
It's normal for your NV200 to have a high idle speed of 2000 RPM when you start it cold, and then drop to 800 RPM after about a minute. This process helps the engine warm up. However, if it feels inconvenient, you might want to consult a mechanic to see if any adjustments can be made.
In normal mode, when coasting after releasing the throttle, the car jerks when the speed drops to 5 KM/h. Is everyone experiencing this too?
Has anyone else encountered this issue? Recently, when I activate the auto hold, after the car stops, the AVH light blinks and then there's a clicking sound. It happens every time. If I press the brake harder, the sound is louder; if I press lightly, the sound is softer.
After changing the drive shaft of a 12-year-old Korean imported car, it makes noise when you press the accelerator, but the noise stops after 2000 RPM. Fellow car enthusiasts, have you encountered this situation? How did you solve it?
When starting the Jetour X90 Zilong, the throttle response is decent, and the power comes immediately. However, after reaching 70 km/h and releasing the throttle, if you want to accelerate again, there's a 1-second delay before the power suddenly kicks in. This isn't the same as getting power instantly when you press the throttle. What's going on here?
Has anyone experienced the issue where the RPM doesn't drop after releasing the throttle on a Cayenne? Looking for solutions. 🙏
Landrover Land Rover Defender
Land Rover DefenderAED 237,600 ~ 677,390Gasoline
