محمد فخريل دين
2024-08-24 16:00
Hi everyone, I have a rattling noise on the roof. It doesn't make a sound on asphalt roads, but on bumpy roads, it keeps rattling. Has anyone experienced noise from the roof and how did you solve it?
خالد علياء
خالد علياء2024-09-10 13:03
Cushion padding
عمر نعيم
عمر نعيم2024-09-01 16:10
It was like this on the first day I bought it, then I removed the padding and added some sponge.
عبدالله أرسلان
عبدالله أرسلان2024-08-30 23:22
As long as the car looks good, it can still be driven.
محمد شاكر
محمد شاكر2024-08-28 08:29
Did you really buy a genuine Land Rover?
محمد عائشة
محمد عائشة2024-08-24 22:56
If you have a small backpack, check if the screws are loose.
Does your F150 have any rattling noise? Mine might be due to driving on dirt roads a lot, there's a bit of noise, like the sound of leather rubbing.
When driving the Multivan T6, if the electric sliding door makes a squeaking noise on bumpy roads, which sounds like metal friction, what solutions are there?
Hey everyone, I recently noticed a rustling noise near the B-pillar on the passenger side when driving over bumpy roads. I've had the car for a year, but this just started happening. It doesn't make noise on regular bumpy roads, only when the car sways side to side. I've tried fastening the seatbelt and applying grease to the buckle, but the noise persists. Has anyone else experienced this? Any suggestions on how to fix it?
Can the rubber bushings be replaced? The car makes a lot of noise when driving over bumpy roads.
Is there any car owner experiencing a noise from the right rear wheel? When the temperature is low, there's a squeaking sound when going over speed bumps. There's no abnormality during normal driving, and it doesn't make noise on bumpy roads. The shock absorber isn't leaking either. The car is only three years old, so it shouldn't be the stabilizer bar bushing issue, plus the sound doesn't seem like it's from the stabilizer bar bushing.
A car from March 2024, there's a rattling sound on concrete roads. The trunk makes noise, the center console island makes noise, and the seats make noise. It feels like the whole car is rattling.
The accelerator feels weak, and the control arm is making a rattling noise.
Does your SUV make a buzzing noise from the rear passenger side when driving at speeds of 20-30 on bumpy roads? There's no such sound from the driver's side. Without some music, it's really hard to ignore that noise!
The 2012 Skoda Octavia 1.6 automatic makes a rattling noise during cold starts! There is a knocking sound when shifting gears!
Landrover Land Rover Defender
Land Rover DefenderAED 237,600 ~ 677,390Gasoline
