Has anyone experienced a noise from the front right wheel, like a screeching sound, especially when lightly pressing the brakes or driving at 20-30 km/h after braking? The noise is very sharp.
Front right wheel makes a noise at low speed.
What could be causing a squeaking noise when lightly braking?
When lightly pressing the brakes on the Vellfire, there's a slight "click" sound. Has anyone else experienced this?
4Hey car enthusiasts, does anyone else notice a squeaking noise with the ID.3 brakes? Especially a "squeak" sound.
5Hasn't anyone mentioned the noise issues with this car? In summer, there's some noise from the right rear door area, and in winter, it's from the right front.
6Hi everyone, when I drive fast and press the brakes a bit hard, there's a thudding sound and the brake pedal feels like it's bouncing. This doesn't happen when I'm driving slowly or pressing the brakes lightly. Is this the ABS system kicking in or is it an issue with the brake pads? Also, regarding the temperature gauge on the dashboard, I remember it used to show two bars as soon as I started the car, right in the middle, but now it takes a few minutes to gradually rise half a bar at a time. Am I remembering wrong or is the coolant level low?
7For a 2020 GS5 with over 30,000 kilometers, experiencing continuous jerking when lightly pressing the accelerator at speeds above 100 km/h, but not when pressing slightly deeper, and with no fault codes, what could be the issue?
8When the car speed is within 20 km/h, there's a squeaking noise from the left rear wheel, and the brake pads are normal.
9For a 10-year-old black Jetta, when lightly pressing the brake, the ABS engages, and at around 10 mph, the ABS starts working. What have others replaced to solve this issue? [facepalm]
10Has anyone experienced a noise from the front right wheel, like a screeching sound, especially when lightly pressing the brakes or driving at 20-30 km/h after braking? The noise is very sharp.
