علي جم
2022-12-22 20:37
The passenger side window suddenly won't go up or down, and the driver's side window has broken once before. I can't really vouch for Iveco's quality!
عبد العزيز نعمان
عبد العزيز نعمان2022-12-23 21:08
Is there any quality to unfinished products? [smirk]
Is the severe shaking of the driver's side window when lowered a common issue with the Lingfang?
After washing the car, the front door windows won't roll down. The buttons aren't responding. Has anyone experienced this before?
Hi everyone, for the 2019 Hongqi H7, is it possible to move the gear lever button from the passenger side to the driver side?
The co-driver's window of the Mitsubishi Eclipse Cross can only go up but not down, and the main driver's switch can control the other three windows except the co-driver's, which can only go up but not down. The co-driver's switch also only allows the window to go up but not down. What could be the reason for this?
After turning off the engine and locking the car, the driver's side window automatically rolls down. While driving, the driver's window button is sometimes responsive and sometimes not. Whether raising or lowering, once the button is pressed, the window moves directly to the bottom and won't stop in the middle. After reaching the end, you can still hear a clicking sound inside the door panel. Is the window button broken? Could you provide a replacement tutorial, preferably with a video?
Today, I suddenly found that the driver's side window won't roll down, but I can hear the motor running. What could be the issue?
Does anyone know why the rear window won't go up or down? Thanks!
My keyless entry only works on the rear side of the driver's seat. Is it broken?
Can the footwell lights of the RDX for both the driver and passenger sides be adjusted to be brighter?
