محمد حازم
2023-03-24 15:14
I have an Iveco Daily with a short wheelbase and low roof. I'm thinking of replacing the rear steel plate. What type should I go for? I usually carry about two to three tons of cargo. Hope someone with knowledge can help me out.
Comments( 6 )
زين سعود
زين سعود2023-09-08 09:24
Iveco is good. Foton and Ford have an unstable chassis. When carrying heavy loads, it causes tire wear. The chassis deforms, making one side higher than the other. From my personal experience, the Ford New Times has severe tire wear when hauling, and the chassis is uneven, making the driver's seat slanted.
خالد نادر
خالد نادر2023-05-28 11:17
Those who modify trucks can probably handle this. It's a good idea to ask several truck repair shops. You need to replace the leaf springs, U-bolts, and screws.
خالد عمر
خالد عمر2023-05-22 12:52
Has anyone recently bought a new car? How is it? I'm thinking of getting a GWM Voleex C30 with a long wheelbase, high roof, and manual transmission for cafeteria use! Any advice? 👏
سلمان حارثي
سلمان حارثي2023-05-21 09:45
Add a piece of spring steel, or replace it with a whole set of the cargo version steel plates if that doesn't work.
علي صعدة
علي صعدة2023-05-01 19:38
You don't need to change it after just a couple of uses.
2
عبدالله جلال الدين
عبدالله جلال الدين2023-03-27 01:03
Why replace it? Just add it on.
