How can I prevent the rear lights from turning on as soon as the door is opened?
How do you unlock the child lock on the 19zs rear door? It's annoying that the door can only be opened from the outside.
How can I prevent the average fuel consumption from resetting on a 2016 Rapid?
For the 2012 Honda City, the doors can only be opened after turning off the engine. How can you set it to open the doors without turning off the engine? Also, when the car starts and you press the brake, the doors automatically lock.
4How can I prevent the headlights from turning on when I press the unlock button?
5Hey folks, does anyone know how to set the dome light to turn on when the door is opened on a 2009 Kia Sportage?
6How can I prevent the rear lights from turning on as soon as the door is opened?
7The child lock on the right rear door of the 2014 V60 is not engaged, but the door cannot be opened from the inside, only from the outside. What could be the issue?
8The car often reports that it can't detect the key as soon as I open the door... The key is a replacement. What's going on?
9If the engine isn't turned off, can the doors not be opened from the outside? I'm new to this, and it was awkward twice today. 😅
10The rear door of the Jetour X90 Zilong Edition cannot be opened from both the inside and outside.
