How can I fix the squeaking noise from the middle door when driving over bumps? Does anyone else have this issue with their car?
The 2014 Model S P85 makes a rattling noise from the right side of the chassis when going over small bumps, manhole covers, and speed bumps. I've already replaced the control arms, but the noise is still there. Does anyone else have the same issue? How can it be resolved?
How to fix the noise from the middle door?
The long-range version produced last October has developed a squeaking noise at the driver's seat back after 15,000 kilometers. It happens on uneven surfaces, potholes, speed bumps, etc., making a creaking sound. Has anyone else experienced a similar issue with their car?
4When driving over slightly rough roads, there's a clanking noise from under the front wheels, like metal hitting metal. Has anyone else experienced this?
5There's a squeaking noise from the front suspension of the Haval when going over speed bumps or uneven roads!
6I'm wondering if anyone knows what might be causing a noise from the rear wheels of a 2006 4Runner when going over bumps?
7Help needed, the suspension of my V40 makes squeaky noises when getting in and out or going over speed bumps. I called for advice and they said it might be due to aging bushings. Has anyone else encountered this issue?
8Has anyone encountered noise from the door check strap hinge? Lubrication didn't help. Can it be fixed by myself?
9Hey car enthusiasts, does anyone else notice a squeaking noise with the ID.3 brakes? Especially a "squeak" sound.
10How can I fix the squeaking noise from the middle door when driving over bumps? Does anyone else have this issue with their car?
