أحمد لاويل
2021-09-03 12:43
Has anyone experienced the issue of the steering wheel shaking at speeds between 105-120 with the Iveco Daily, and if so, do you have any viable solutions?
Comments( 20 )
حسين رومي
حسين رومي2023-05-12 23:15
The new car shakes right out of the dealership.
عبدالرحمن ق
عبدالرحمن ق2023-05-12 07:06
Washing your car when the brake discs are overheated can cause them to warp, which might lead to vibrations when driving over 100 km/h. This happened with my sedan, but it was resolved after I replaced the brake discs.
حسين احمد
حسين احمد2023-05-11 09:38
Replace with high-quality alloy wheels. I've replaced them, and the issue is resolved. No shaking at 150 km/h.
عبد العزيز حبيب
عبد العزيز حبيب2023-05-08 20:40
Try inflating the tires to the standard pressure and see if it makes a difference.
نايف جم دين
نايف جم دين2023-04-15 20:14
If it's a 5-speed transmission, it's not recommended to exceed 100 km/h. IVECO may leak oil if driven too fast.
خالد نبيل
خالد نبيل2023-04-08 12:28
Is it possible that the driveshaft is shaking?
2
فهد زين
فهد زين2023-04-05 21:13
The toe alignment is off, just adjust it and it'll be fine.
عبدالرحمن فخر دين
عبدالرحمن فخر دين2023-03-06 18:28
This car isn't suitable for speeds over 100. With crosswinds and uneven roads, steering wheel vibration is normal. Keep it under 100, and it's fine.
عبدالله إدريسي
عبدالله إدريسي2021-10-18 21:06
I need to replace the front wheel hub bearing.
حسن شادي
حسن شادي2021-10-17 08:40
My 2045 shakes between 115-120 km/h, but it gets better after 125. It's quite thrilling to constantly watch the speedometer and the monitor on the highway.
Is it normal for the steering wheel to shake when driving at 120 km/h on the highway after the car has been driven for 100,000 kilometers?
The steering wheel of the 2016 Crossover Yizhi is not aligned properly and is tilted to the left. The left side is further from the driver, and the right side is closer. Has anyone else experienced this issue, and is there a solution?
2014 Peugeot 3008, 2.0, experiencing shaking between speeds of 60 and 80 km/h, similar to engine stalling. What might be the issue?
Hey folks, has anyone experienced their V40 shaking at speeds between 100 to 120 km/h, but then it stops shaking once it hits 150 km/h? I have an 18 model T5 with 55,200 km on it.
Iveco Ousheng, the new car was registered on June 1st. When driving above 110 km/h, the steering wheel starts to shake. Is it serious?
Does your steering wheel shake a lot when you brake at speeds over 60? Have any of you experienced this phenomenon?
Recently, on the highway, my steering wheel was shaking. Has anyone else experienced this?
It sounds like you are experiencing a vibration issue with your vehicle, especially noticeable at certain speeds. After performing wheel balancing, the shaking became more pronounced between 100 to 110 km/h, even reaching the seats, but it disappears at 120 km/h. You also mentioned that at low speeds on uneven cement roads, there is a resonance from the engine compartment to the steering wheel. These symptoms might indicate an issue with the wheel alignment, tire condition, or suspension components. It would be advisable to have a professional mechanic inspect the vehicle to diagnose and resolve the problem accurately.
When my car reaches a speed of 110, the steering wheel starts to shake. What's going on with that?
