What bulbs have you all changed the lights of the Arrizo 5 to?
Is there a Chery Arrizo 5 1.5L manual version?
What tires are you all using? It's been six years, time to change them.
The rear tail light on the driver's side doesn't light up when I brake. I just replaced the bulb half a month ago, and now it's not lighting up again. The previous inspection said it wasn't a bulb issue. Has anyone else experienced this? What's the problem?
4I bought a used 2018 Peugeot 3008 and feel like the halogen lights aren't bright enough. I replaced them with LED bulbs, but the light is still scattered and not good. Could you suggest what bulbs I should use? Also, does the original car come with projector lenses?
5What bulbs have you all changed the lights of the Arrizo 5 to?
6What is the real fuel consumption of the 2024 Chery Arrizo 5 manual transmission model?
7Can the Venza be fitted with laser light bulbs?
8Can the 2017 Arrizo 5 use CarPlay? Has anyone used it?
9What's the RPM of your 2024 Chery Arrizo 5 manual when driving at 120 km/h on the highway?
10How much is the lowest configuration of the Chery Arrizo 5 manual version?
