Mazda CX-7 has two versions: a 2.5L naturally aspirated engine and a 2.3T turbocharged one. I'm currently driving the 2.5 version and want to add a turbo. Is it possible to convert it since there is a turbo version available? Does it have more tuning potential compared to other Mazda models? Looking for advice from experts.
To determine which is larger, a 1.5L engine or a 1.4T engine, you need to understand the difference between naturally aspirated engines and turbocharged engines. A 1.5L engine refers to a naturally aspirated engine with a displacement of 1.5 liters. On the other hand, a 1.4T engine has a displacement of 1.4 liters but is turbocharged, meaning it has a turbocharger that increases its power output. In terms of displacement alone, 1.5L is larger than 1.4L. However, the turbocharger in the 1.4T can provide additional horsepower and torque, potentially making it feel more powerful than the 1.5L, depending on the specific engine designs and tuning. So, if you're looking at just the displacement, 1.5L is larger. But in terms of performance, the 1.4T might offer more power due to the turbocharging.
Mazda CX-7, 2.5 uses what type of transmission oil?
What type of transmission fluid should be used for a Mazda CX-7 2.5?
4How can I find out which version of the 2020 registered 1.5 naturally aspirated automatic Buick Excelle I bought?
5How is the fuel economy of the 2017 Mazda CX-5 with a 2.5-liter engine and all-wheel drive?
6Is there a big difference in driving feel between a 1.0 naturally aspirated engine and a 1.0 turbocharged engine?
7How to choose between a 3.0 naturally aspirated engine and a 2.0 turbocharged engine?
8Where can I activate the active braking on the Cetus 1.5L naturally aspirated, luxury version?
9I just bought a Subaru Forester 2.5 naturally aspirated. Is a fuel consumption of 13 with the air conditioning on normal? I would like to ask for advice from experienced users.
10If I add a turbo to a 2.5 Forester, can the transmission handle it? Or should I go for a stage 2 tune? The brake pads definitely need to be replaced, but I'm worried the transmission might not handle it, even though Subaru's transmissions are quite strong.
