علي جل
2020-12-28 17:19
Is the fuel filter built-in?
عبدالله عاطف2021-02-07 18:34
It's built into the fuel pump, so if you're replacing it, it's recommended to replace it together with the fuel pump.
عبد العزيز عبد الوهاب2020-12-28 18:21
The car's filter is built into the fuel pump, so for this vehicle, it's basically an internal type. It's not easy to disassemble and install.
Where is the fuel filter located on a 2020 F150?
How do you open the built-in sunglasses holder in the car?
4Does the Maxus T60 gasoline version have a fuel filter? How many kilometers should it be replaced?
5Does the Navara have an anti-theft filter in the fuel tank?
6Does anyone know where the fuel filter is located on the 2021 F150?
7How often should the fuel filter of a Mitsubishi ASX 1.6L be replaced?
8When will a factory be built domestically?
9Why are the gasoline filters in other Trumpchi models external, while in the GA6, it's integrated with the fuel pump?
10How often should the fuel filter of a 2019 Changan Yuexiang be replaced? Looking for advice online.
