لبيب عبدالله
لبيب عبدالله
Dec 2
Where can I find the total mileage display in the GWM Pro when it only shows A and B trip meters?
عبدالله عماد
عبدالله عماد2024-12-02 15:20
The number on the left side of the fuel gauge.
أحمد عبد القادر
أحمد عبد القادر2024-12-02 11:34
I also can't find where to check the total mileage.
This is a 2007 model with a 1.4 engine, showing a mileage of 210,000 kilometers. It has only changed ownership once, and both the exterior and interior are in good condition. The insurance is valid until December. The asking price is 5000 and does not include the transfer fee. Should I consider buying it?
How to install a dash cam? I can't find a place to run the cables. Can anyone help with this? It would be great if you could show where the cables should go. Thanks! 🙏
To reset the trip meter A on a Haima S5, it's usually done with a small button on the instrument panel. If you can't find it, refer to the owner's manual for specific instructions, as the button might be less visible or located differently.
Have you encountered a situation where the reverse camera image is missing the borders and only the image is displayed? How can it be restored to normal?
Hey guys, how do you reset the trip meter above the total mileage on the dashboard? I have a 2011 base model, manual transmission, 1.4L hatchback.
Taycan owners, I have a question about a feature. As you might know, in the Taycan's triple display, the middle one shows the speed by default, and when the power meter is checked, it shows acceleration and energy recovery levels—blue for acceleration and green for recovery. In my car, with the default set to normal mode, when I press the accelerator, the blue bar shows up normally. However, when I press the brake, the green bar doesn't show at all, although the car brakes fine. Does this mean my braking relies solely on mechanical brakes without energy recovery? Is there a way to set it so the green bar shows normally when braking? I'm sincerely asking for advice, thanks everyone!
The display used to show that a full tank could last over 1000 kilometers. Now it only shows 710. What's going on?
I got a 2011 manual 1.4 Peugeot 207 for my wife to practice driving. The car just arrived, and I have a few questions for experienced owners. 1. Does this car not show fuel consumption on the display, do I have to calculate it myself? 2. The original parking sensors make a beeping sound, but is there a distance display? Where can I find it? I couldn't locate it. 3. When the vehicle is running and I turn the key to the ignition position, there's a clicking sound. What's the issue?
Hi, buddy! If you're trying to change the music in your Alphard and can't find where to plug in the USB, I totally get it. In the Toyota Alphard, the USB port is usually located in the center console or near the dashboard. Sometimes, it can be a bit hidden, so you might need to check around those areas carefully. Hope this helps!
What's the total height of a Prado with a roof rack? My parking garage is only 2 meters high, so I'm quite concerned.
Mazda CX5
Mazda CX5KWD 6,800 ~ 11,050Gasoline & Petrol
