Does your CX-5 make a cicada-like noise at low speeds, especially noticeable when coasting at 60? Have any of you experienced this?
I've had the top-end version of the Venucia Star for a year, and I've driven 4800 kilometers. Now I've noticed that when going over those really low speed bumps on highways, the rear end sways, with noticeable lateral movement at the back. (Speed is under 60, and ESP is automatically on.) Do you guys have the same issue?
When driving at high speed in the 2020 top-spec Legacy, I notice the suspension makes a "gugu" noise. I'm curious if others have experienced this as well.
Does your steering wheel shake a lot when you brake at speeds over 60? Have any of you experienced this phenomenon?
4In normal mode, when coasting after releasing the throttle, the car jerks when the speed drops to 5 KM/h. Is everyone experiencing this too?
5Hey car enthusiasts, does anyone else notice a squeaking noise with the ID.3 brakes? Especially a "squeak" sound.
6When starting, there's a noticeable vibration, but the higher the speed, the less the vibration. There's no vibration when coasting, but as soon as you accelerate, you feel it, especially at lower speeds. Why is that? There's no unusual noise. I've already replaced the left half axle, engine mounts, and recently changed the tires and ignition coils. The repair shop says it's an issue with the transmission and it needs repairs. Is that true? 😮💨
7Does your CX-5 make a cicada-like noise at low speeds, especially noticeable when coasting at 60? Have any of you experienced this?
8Does your engine also make a loud noise when the RPM reaches 2000? Especially when going uphill, all I can hear is the roar of the engine.
9Do you hear a clunking noise when you brake or release the brake while driving your car at low speeds?
10How can I turn off the low-speed warning sound on the Toyota bZ3? It's so annoying, especially late at night!
