عمر حريري
عمر حريري
Jul 21
When merging onto the highway with a CX-30 MT, which gear do you use to accelerate? From 50-80 km/h, there's not much power in 4th to 6th gear. Do you need to rev it up to 100 in 3rd gear?
Comments( 20 )
هارون حسين
هارون حسين2024-10-24 22:02
Start in 2nd gear, shift to 3rd at 60, then to 4th at 100, and finally to 5th after 120.
نايف همام
نايف همام2024-10-23 14:13
I feel like this car has the most power at 3500 RPM. The engine sounds normal at that point, but over 4000 RPM, it starts to sound a bit scary. I guess the factory oil might not be suitable for running above 4000 RPM.
حسين مستعصم
حسين مستعصم2024-10-19 20:39
When shifting gears from 1-2 and 2-3, if the RPM is above 4000, it should be enough for you to accelerate faster than most cars. Then, when shifting from 3-4, press until 3000 RPM. The key point is to use 98-octane fuel.
أحمد صادق
أحمد صادق2024-10-19 17:04
Stepping on the gas pedal, surely there's no power if you don't step on it. 😁
حسين جعفر
حسين جعفر2024-10-18 16:16
Shift into neutral and coast once you gain speed, [666].
عين عبدالرحمن
عين عبدالرحمن2024-09-03 13:27
With a manual 4-speed, it's enough. Let the 5th and 6th gears rest. ✌️
حسين أسد
حسين أسد2024-09-02 10:39
Is it easy to buy a manual transmission car now?
نايف مستنصر
نايف مستنصر2024-09-02 09:13
5th or 6th gear. Want to accelerate quickly at 80... Shift down, yeah...
شادي نايف
شادي نايف2024-09-01 12:34
Second gear sprint, pedal to the metal!
سعود لاويل
سعود لاويل2024-08-31 11:21
When entering a ramp with a curve, it's recommended to drive at 40-50 km/h. If there's no curve, check for oncoming traffic behind you, then shift gears at 3000 RPM to accelerate to 90-110 km/h. Once on the main road, increase your speed to 100-120 km/h.
The 1.4T model keeps showing a fault light, and there's no 2nd, 4th, and 6th gear. The computer, valve body, and clutch have all been replaced, but the issue persists. How can this be resolved? Has anyone encountered this?
Fellow car enthusiasts, have you experienced slow shifting between the 6th and 7th gears with your 7-speed dry dual-clutch transmission? Mine doesn't shift to 7th gear even at 80 km/h and waits until it reaches 85 km/h. Is this normal?
Is it a problem with the gearbox if sometimes the 4th gear won't shift down to the 3rd gear in a 2015 Honda City with a manual transmission? Waiting online for someone knowledgeable about cars to answer.
This brand-new car costs 80, and as soon as you drive it 0.01 kilometers as a used car, you lose 50! Buying this car for 80 is a sure loss.
Hey car enthusiasts, how do you guys shift gears with a 1.3L manual? 2nd gear at 20-40, 3rd at 40-60, 4th at 60-80, and 5th above 80!
Does the S gear shift up and down? Why can it only be in 1st gear and not in 2nd, 3rd, or 4th gear?
Hey car enthusiasts, how long have you been driving the Santana with the Aisin 6AT automatic transmission? Is it prone to issues? I've read online that it might have noise issues and jerking between 3rd and 4th gear. Is this transmission really durable?
I have a 2021 model Santana. When I'm driving between 50 to 60 km/h, the gear is in 5th, but the display shows 2nd or 3rd gear. However, the 2nd and 3rd gears seem to be neutral. What's going on?
Hey fellow car enthusiasts, do you also notice that when you start the car in P gear, the engine revs quite loudly, usually above 1000 RPM? But once you shift to D gear, it drops below 1000 RPM and the sound gets much quieter. Is that the case for you too?
Mazda CX30
Mazda CX30KWD 6,700 ~ 10,250Gasoline & Petrol
