سلمان منذر
2024-11-16 15:19
Start the vehicle, press the brake, and there's a noise from the gear lever.
عبدالله هاماوي
عبدالله هاماوي2024-11-17 21:21
Does it sound like a relay clicking?
I have a 2018 2.0 4WD Jeep Renegade. When I start the car, while the gear is in the P position and I press the brake, I hear a clicking sound from the gear area. Has anyone else experienced the same issue?
Does anyone know where to replace an electronic gear lever?
When the 2006 Legacy is in drive and you press the brake, there's a "doo doo" noise from the chassis, and the steering wheel and brake pedal vibrate. Sometimes it's mild, sometimes strong, and sometimes there's no issue at all. Could it be because the brake silencer pads weren't installed properly?
Hi everyone, for the 2019 Hongqi H7, is it possible to move the gear lever button from the passenger side to the driver side?
I have a question. Today while driving, I noticed that the gear shift lever on my automatic transmission can be shifted without pressing the button on the handle. Is this a problem?
Why is the plastic near the gear lever on the passenger side very hot?
When the vehicle just starts, there's a whistling sound from the front wheels, but it disappears after driving for a while. What's the reason? Could it be that a small stone got into the brake disc?
Is it normal for the car to shake when downshifting from 3rd to 2nd gear while braking?
Has anyone experienced a noise from the front right wheel, like a screeching sound, especially when lightly pressing the brakes or driving at 20-30 km/h after braking? The noise is very sharp.
Mazda Mazda CX30
Mazda CX30AED 95,000 ~ 100,500Gasoline
